Maya fur not rendering on extruded faces
COW Forums : Autodesk Maya
Aaron Debreczeni
on Aug 14, 2009 at 11:53:56 am
Hi there,
can somebody tell me why maya fur doesn't appear on faces that were created with extrusion?
And another question: how can i apply fur to only some selected faces on an object?
Thank you
Aaron Debreczeni
internal tester
Re: Maya fur not rendering on extruded faces
on Jan 16, 2010 at 10:35:00 pm
You need to remap the object's UVs after extruding faces.
Set Maya to Polygons mode, then "Create UVs > Automatic Mapping"
Hair should then correctly cover the entire object.
