Maya Selction Issues : Selects mirror opposite
COW Forums : Autodesk Maya
michael zoppo
on Aug 12, 2009 at 2:30:15 pm
When selecting vertex on a box in Maya I have come across the problem were if i try to select two or more vertices on a box then it also selects the same vertex's on the opposite side of the box.
Is this a pref i accidentally turned on?
Matt Nielsen
Re: Maya Selction Issues : Selects mirror opposite
on Aug 12, 2009 at 10:38:03 pm
How are you selecting them? Click and drag or shift select..
Shoban Reddy
on Aug 21, 2009 at 2:45:38 pm
I had an small salvation for that.
Goto Polygons[Menuset]-Dislay[Menu]-polygons[Sub Menu]-Backface Culling..
Try This..
Shoban Reddy
on Aug 21, 2009 at 2:48:47 pm
Try This..
Rein Blank
on Sep 1, 2009 at 11:27:57 am
I have the same problem and tried the backface culling, but it didn't work.
It constantly selects the miror edge or face in both polygon and surface mode.
Hope somebody knows where the 'off' switch is.
Thx
Alvaro Castaneda
on Sep 1, 2009 at 2:25:37 pm
I think you have mirroring on
double click the tool you're having trouble with and look for reflection in the settings panel, toggle it off
varomix - pixelEater
http://www.intelianimate.com
Celso Soares
on Mar 15, 2010 at 4:47:13 pm
Thanks dude, I've been searching for over an hour for a fix for this! BTW whoever decided to put that checkbox hidden in a double-click-on-tool menu, I hope you die a horrible death!
