Animating multiple instances with offset
COW Forums : Autodesk Maya
Per Spook
on Aug 5, 2009 at 7:16:03 am
I have about 200 fence posts that are supposed to scale up from the ground in a sequential manner. I can select all of the fence posts and animate them, but then I have to offset the animation manually which I really don’t want to. Maybe I’m being stupid here, but I cant figure out an easy way to do it.. anyone have a solution for this, or a simple script?
Per Spook
Re: Animating multiple instances with offset
on Aug 6, 2009 at 8:18:10 am
Thats it! Thank you...
Per Spook
on Aug 7, 2009 at 11:33:47 am
Hi Michiel,
I'm wondering if you can help me out with one more thing??
Say, I want to ad a rotation to the script as well. so that the pcube both scales in Y and rotates in Z from 45 down to 0.
Do you have a solution for this?
