halftones in maya
COW Forums : Autodesk Maya
bert Rodriguez
halftones in maya
on Jul 30, 2009 at 5:12:16 pm
I would like to know is there anyway to key a switch between cameras or connect multiple cameras to a projection node after setting up haltone set up created by Alvaro Castaneda? ITs for an animation and there are lot of camera involve.
Alvaro Castaneda
Re: halftones in maya
on Jul 30, 2009 at 9:55:26 pm
Hi
There are several way that you could manage that, I usually do one camera and key frame that even for cuts, you could also use several cameras and just animate the link to camera property of the projection node to match your cuts, I prefer the one camera method. :D
glad you can put that tutorial to good use
Thank you
varomix - pixelEater
http://www.intelianimate.com
bert Rodriguez
on Aug 2, 2009 at 5:13:01 am
Thank you responding quickly, how do you animate the camera links in maya 2008_
