Reflections from an Image Sequence
COW Forums : Autodesk Maya
Madhav Shidhaye
on Jul 23, 2009 at 9:36:29 pm
Hi.
I have a sequence of 24 PNG images.These were from a video footage.
I want my 3d objects like a polygon cylinder for instance to be able to reflect the PNG still images.
What is the proper way to do this?
When I tried it (using an image plane, projection mapping etc), the PNG images are tiled on to the cylinder and that is not what I want.
Thanks in advance.
Alvaro Castaneda
Re: Reflections from an Image Sequence
on Jul 25, 2009 at 8:04:26 pm
Hi
You could map those images to a polyplane and put that in front or where you need it to be, than turn the primary visibility, cast and receive shadows of on the plane.
156_reflectionexample.ma.zip
Check the sample file :D
varomix - pixelEater
http://www.intelianimate.com
