Toon Render Close up
COW Forums : Autodesk Maya
elijah stanfield
on Jul 15, 2009 at 8:58:09 pm
I'm trying to get a close up of a toon shaded building, but the most of the lines dissapear when I render. Is there a way to fix this or do I have to come up with another solution?
Michiel Duvekot
Re: Toon Render Close up
on Jul 15, 2009 at 10:14:49 pm
Turn on Resample Crease (the creases are likely what's failing) in the Line Resampling section of the Attribute Editor for the pfxToon and set the Max Segment Length to something that is less than the length of an edge on your model. If that still doesn't work (and you've made sure it's not the creatses that are failing, convert the pfx to polys with [Rendering] Toon->Convert Toon To Polygons or Modify->Convert->Paint Effects to Polygons.
Michiel
http://www.thnkr.com
elijah stanfield
on Jul 15, 2009 at 11:29:01 pm
This worked marvelously. Thanks.
