Maya Rendering - Mental Ray Issue
COW Forums : Autodesk Maya
Brian Tran
on Jul 15, 2009 at 10:29:31 am
Hi, I'm new to using Mental Ray to render in Maya. I would like to use Mental Ray since it renders much faster than the software render, however, I am experiencing some issues.
Rendering using Maya Software
Rendering using Mental Ray
If you look at the two images above, you will see that I get a pixelated refraction image from using Mental Ray. Maya Software render is what I want my final render to produce. Does anyone know how I can fix this? I discovered that if I lower the refractions setting to 0 then it goes away, but then it becomes very dark since there is no refractions. Please help me!
© 2018 All Rights Reserved
