Maya crash whenever I try to snap pivot
COW Forums : Autodesk Maya
Martin Klekner
on Jul 11, 2009 at 1:44:17 pm
Hi, i have a very strange problem on my MacBookPro (OSX 10.5.7).
Im running Maya 2009 Unlimited and whenever i hit the insert key, move the pivot and try to snap it (holding down X,C or V), the viewport freezes and no controls work. Can't move, rotate, select or anything. Other viewports are fine, its just the case of the one i used the snapping in.
This is happening only with the pivot snapping, when i try to snap a vertex or any other object, it works fine.
Id very much appreciate those of you who may have had a similar problem to tell me if theres any solution. Its not a major problem, but pivot snapping definitely helps my workflow :-)
Thanks a lot, Martin
© 2018 All Rights Reserved
