Help rig-animation qn
COW Forums : Autodesk Maya
jerold lir
on Jul 6, 2009 at 5:38:54 pm
Hi.I am pretty new to maya and i would like to post a qn regarding rigging and animation.I have failed to freeze all transformations and values before going into rigging.I would like to query if failure to have a default T-pose and not returning all values to zero on the rig would result in the rig going haywire during my animation process.If so is there any way i can still freeze the transformations w/out having to rerig.Is it advisable to continue animating or rerigging?Thanks.
Alvaro Castaneda
Re: Help rig-animation qn
on Jul 6, 2009 at 6:07:19 pm
What you can do is add a keyframe to every control in you rig at frame -10, and use that as your T or stand pose, it won't blow up, I can promise you that :D
it might be a little tricky to animate but only that.
varomix - pixelEater
© 2018 All Rights Reserved
