Cannot animate
COW Forums : Autodesk Maya
jack halsey
Cannot animate
on Jun 14, 2009 at 2:30:36 am
I am having trouble animating. All I wish to do is a camera zoom in on a rooftop. You start up above the house showing the estate and then the camera zooms in thru the roof.
I selected the stereo camera and then set the cameras where I wanted them and set the keyframe. Then I moved the cameras thru the house and set another keyframe.
When I try to animate it only animates one frame.
Please advise and thank you.
Michiel Duvekot
Re: Cannot animate
on Jun 14, 2009 at 4:08:52 pm
Did you set that second keyframe at the right time? If not, open the graph editor, select the key(s), and type in the new correct time in the leftmost box next to stats.
© 2018 All Rights Reserved
