Problem Moving a CV on a CV Curve
COW Forums : Autodesk Maya
Lars Koerkemeier
on Jun 4, 2009 at 3:52:11 am
Hello,
This is probably a simple question but im using Maya 2008 and if i make a CV curve and try to edit the cv's by using the move tool it doesnt only move the selected cv but it ends up moving must of the points around it to. I have tried changing the move axis but it always does the same thing.
If you dont understand what i mean let me know.
Lars
Michiel Duvekot
Re: Problem Moving a CV on a CV Curve
on Jun 4, 2009 at 11:40:06 am
Check that soft select is off in the Move Tool Settings (or try pressing the 'b' hotkey to toggle soft select.
Michiel
http://www.thnkr.com
Lars Koerkemeier
on Jun 4, 2009 at 12:40:01 pm
That was the problem.
Thanks a lot!
-Lars
