24 FPS Batch Render?
COW Forums : Autodesk Maya
Rickey Cloudsdale
on May 27, 2009 at 10:54:22 pm
I am trying to render out a sequence I did in maya in sync to the music and in maya it was fine, but when I went into AE it says that it was rendered out a 29.99fps and doesn't sync with the music correctly. Any help please project due tomorrow ><
Alvaro Castaneda
Re: 24 FPS Batch Render?
on May 28, 2009 at 4:37:38 am
I guess you rendered an image sequence, if that is the case, change the frame rate for the sequence, right click on it and choose interpret footage, there change the frame rate
also check the settings for the composition, press ctrl + k while in the composition and change the frame rate there too
hope that works
ooh and, don't forget to extend the clip
varomix - pixelEater
© 2018 All Rights Reserved
