Approximation Editor (displacement Map) And Hard Edges. How do I keep my edge corners hard, while displacing inside?
COW Forums : Autodesk Maya
Robert Morris
on May 26, 2009 at 4:21:51 pm
I've created a simple polygon box and deleted the top and bottom. Then, I've drawn a grayscale displacement map and applied it to the displacement on the blinn material so the surface of my object can have displacement detail. In order to get a good displacement, I've created a Subdivision Approximation node on the object and set the method to Parametric with N subdivisions set to the default 2.
When I render in mental ray (set to production quality) the edges/corners of the box collapse in on themselves as if the approximation editor is trying to smooth the entire object. How can I set my 4 corners to not do this and remain hard edge (square) corners? I'm using Maya 2009, by the way. Thanks.
Fine Art Drawings | Photography | Compositing | VFX | Titles | Keying | 3D
Alvaro Castaneda
Re: Approximation Editor (displacement Map) And Hard Edges. How do I keep my edge corners hard, while displacing inside?
on May 28, 2009 at 4:56:02 am
add edges close the edges to maintain the shape
varomix - pixelEater
http://www.intelianimate.com
Robert Morris
on May 28, 2009 at 5:12:57 am
I'm sorry, but that makes no sense to me. Please be more specific.
BTW, my edges are closed, as per my original message.
Alvaro Castaneda
on May 28, 2009 at 5:21:15 am
yeah that sounds weird :D
add edgeloops near the corners so you can keep that detail when you subdivide
hope that makes sense :D
Robert Morris
on May 28, 2009 at 2:05:37 pm
Thanks. I've been adding bevels at the edges. But that still doesn't change the approximation editors effect on my geometry.
