Having Problem with Particles
COW Forums : Autodesk Maya
Salima Nesbitt
on May 26, 2009 at 2:29:42 pm
I'm having a problem with my particles in my final render. They are there playing in my preview window in Maya, but when I rendered the final movie out the particles didn't show up. Is there a setting or something that I'm missing? Any ideas???
Alvaro Castaneda
Re: Having Problem with Particles
on May 26, 2009 at 3:56:59 pm
hi
Yeah, particles are special :)
if you wanna render POINTS or any other that is not SW(software), they WON'T show in the simple render, you need to make a separate pass for particles and render them with the hardware renderer, if you use SW(SOFTWARE) particles this won't be a problem.
l8r
varomix - pixelEater
http://www.intelianimate.com
Salima Nesbitt
on May 26, 2009 at 5:17:20 pm
I kinda understand what your saying, and at the same time I don't. Is there a tutorial anywhere that could show you the difference and how to render the particles out.
Alvaro Castaneda
on May 26, 2009 at 5:38:44 pm
hit render
in the pop up render view, select maya Hardware instead of maya software or mentalray in the middle drop down menu
hit render again
Salima Nesbitt
on May 27, 2009 at 4:10:05 am
Thanks problem solved.
