problem exporting from Mac to PC
COW Forums : Autodesk Maya
Eric Croose
on May 19, 2009 at 1:51:36 am
Hi I am at present on a cource with NatCol here in christchurch NZ. I am having problems opening .MB files, which have been downloaded to a flash drive from the Macs at MatCol, on my home PC. I am told there should be no problem as the versions are the same ,ie Maya 2008.
Any help or suggestions very welcome.
Nate Ball
Re: problem exporting from Mac to PC
on Jun 8, 2009 at 6:43:14 am
Hi, I'm at Natcoll Christchurch at the moment too. For the most part my files work between home and Natcoll fine, however when I start a new object, as soon as I open the file on my home PC it is as though it corrupts the file somehow. Points, polys and vertices from the area I was working on are randomly deleted, merged or moved. Pain in the arse as it seriously slows down what I can do.
Alvaro Castaneda
on Jun 8, 2009 at 3:16:01 pm
hi Nate
Try saving your files in both .ma and .mb
I guess you are using the same version of maya in both places, if not, the .ma file helps you transition to older versions, just open it in a text editor and edit the maya version.
the other thing that can help you is to freeze the model and delete modeling history, hope you haven't rig anything yet :D
hope that helps
varomix - pixelEater
http://www.intelianimate.com
