Is NVIDIA GeForce 8400M GS (128MB)suitable for Maya 2008?
COW Forums : Autodesk Maya
Mirko Menegazzo
on May 16, 2009 at 10:53:34 pm
Hi everybody.
I have to buy a new laptop which is able to run Maya 2008.
The laptop I am interested comes with the NVIDIA GeForce 8400M GS(128MB). I know it is a weak card, but laptops with better cards are far more expensive...I have budget issues...
Thank you for your help
Chad Briggs
Re: Is NVIDIA GeForce 8400M GS (128MB)suitable for Maya 2008?
on May 17, 2009 at 2:31:05 pm
In theory it should work fine. Autodesk does not officially support gaming/non-quadro cards with maya, but most of the world uses them without a problem. I'd google and see if you can find any reports of it working otherwise. You may have display glitches here and there, but i doubt anything would be a show stopper.
-Chad
Alvaro Castaneda
on May 17, 2009 at 5:11:32 pm
yes it should work, I've done that ina a few machines, mostly in linux, if you got any glitches or problems with the display on windows, try the omega drivers, that always works for me on windows, http://www.omegadrivers.net
varomix - pixelEater
http://www.intelianimate.com
Mirko Menegazzo
on May 17, 2009 at 5:37:28 pm
Thank you for your advice, I will check the Omega drivers out.
Does it make any difference if I install Vista or XP (both 32 bit)?
I have heard of some issues using Maya with Vista 64
Mirko Menegazzo
on May 17, 2009 at 5:45:11 pm
Thank you for your reply.
I did a bit of searching and people complain about the ncloth feature and real time rendering both with glitches...I am not going to do any advanced stuff though, I need it for learning purposes that means 3D character modelling and lighting and texturing. By the time I will need to use particles or other advanced features hopefully I will have a powerful desktop to deal with it.
