Rendering in Layers - QUESTION
COW Forums : Autodesk Maya
michael zoppo
on May 5, 2009 at 6:32:26 am
Ok So i have a scene with 3 cubes and a floor.
If I want to render everything in passes/layers i would assign each of the 3 cubes to a different layer and each of those layers would be separated into different layers for diffuse,shadow,highlight passes etc?
Or can all three cubes be in one layer with just one main set of diffuse,shadow,highlight,etc passes for all of them combined?
And my biggest question is if want to render this out to AE instead of having to batch render just the shadows first, then wait for my render to finish, unclick the 'R' next to my shadow pass, then select my highlight pass and batch render that individually and so on for all the different passes. Is there away that all the layers can be batch rendered together but they are serperated individually into different passes, that way I don't have to wait around and waste time rendering out each pass one by one.
Thanks Guys
© 2018 All Rights Reserved
