Texture won't render out
COW Forums : Autodesk Maya
Jeff Fabrizio
on Apr 29, 2009 at 7:22:03 pm
I am fairly new to Maya. I've created a model and assigned textures. Everything looks god in Maya, but when I render out my image sequence, the texture doesn't show up. I did notice on one of my material nodes it says "object not found" but everything looks right. Any suggestion?
Jeff
Shane Barger
Re: Texture won't render out
on May 1, 2009 at 2:24:38 pm
Hmmm. Is your project set to the default folder names? And if so, is the texture you're using saved in your sourceimages folder?
The only other thing I can think of that would be throwing it off is if it some how became unlinked. In your attribute editor try clicking "reload" underneath of the file name of the texture.
Good luck!
-Shane
Jeff Fabrizio
on May 1, 2009 at 7:02:27 pm
Thanks Shane. I am using the default project folders and the texture is in the source images folder. I will give the "reload" a try.
Jeff
