spray painting surfaces
COW Forums : Autodesk Maya
luigi tadiotto
on Apr 21, 2009 at 9:28:13 pm
Ciao, i need to paint a surface, i started with an emitter from particles and make collide with a polygon surface. With the geoconnector i stopped the particles with resilience. The problem is i dont know how to use these particles to interact with the texture of wood of the polyobject. I tried using particle cloud volume shader but the effect is not very remarkable. it would be something that paints layered the wood not over it.
Some ideas, suggests?
Alvaro Castaneda
Re: spray painting surfaces
on Apr 22, 2009 at 3:46:24 pm
I would try to do that on an image sequence, make that in after effects or something like that and then use that as my texture for the object, just using the particles to simulate the can's paint.
or I could try to make that inside of maya with layered texture and something as a mask.
varomix - pixelEater
© 2018 All Rights Reserved
