Importing Keyed Image Sequences.
COW Forums : Autodesk Maya
April Henderson
on Apr 19, 2009 at 5:01:26 pm
Hi there!! I'm trying to bring in greenscreen keyed out image sequence into maya, but am not sure how this is done. The images were rendered RGB+Alpha mode in AFX. I imported one image and it looked fine, but when I rendered the image was surrounded by the black background that was supposed to be invisible. Any tips on how to do this right??
thanks
Alvaro Castaneda
Re: Importing Keyed Image Sequences.
on Apr 20, 2009 at 2:36:56 pm
hi
connect the same image sequence in the transparency channel, if that looks weird create a separate matte sequence, a simple black and white is fine, I like this approach cause you can use that mask in the reflection and specular channel if you need that
varomix - pixelEater
http://www.intelianimate.com
April Henderson
on Apr 20, 2009 at 8:19:09 pm
I realized that the file name appeared to be 'causing trouble. I loaded with Fcheck resaved then reloaded.
thanks!
I noticed the imported image sequence I had on a plane acting pretty weird during renders however. When rendering its position appeared to be behind a bunch of paint effects I had put on a plane even though it was actually positioned in front of them.
