Polygon_Proxymode crashed need help
COW Forums : Autodesk Maya
Michael Balzer
on Apr 4, 2009 at 1:25:33 pm
Hi everybody!
Im very new to Maya but i already have big problems!
So here it is!
I have a subdivision Model an i want to go in Polygon Proxymode!
So i right click on the model and choose from the Marking Menue Polygon.
Normally the Polygon cage should appear!
But instead i get this!!!
You can see that there is a little bit of the cage but its completely broken!
So i convertet this sub d back into a Polygon.
But when i do so i get this
This is the same Model converted from subD into a Polygon Object and with verteces selected!
As you can see there are no longer any Edges!!!
Why is that so.
At first i thought i did anything wrong with the model but i have the same problem with every other subdivision Object.
Even if i create a Polygon cube and convert it in a subD I don't get a Polygon Cage.
I Even tried to reinstall Maya.
But that didn't work as well.
Im really desperate what to do please Help
Greetings Mitch Braggart
Alvaro Castaneda
Re: Polygon_Proxymode crashed need help
on Apr 5, 2009 at 12:59:36 am
I think you are having problems because you are in isolate mode, and by default objects are not loading
get in to normal mode and try again
in the viewport menu
read that for help :P
varomix - pixelEater
© 2018 All Rights Reserved
