Pin Animation like NIN "Only" Video
COW Forums : Autodesk Maya
Francis De La Torre
on Mar 26, 2009 at 7:54:24 pm
I was curious if anybody could give me any leads on how to create a pin aimimation, as seen in the NIN "only" video. I've tried several methods with not luck.
also, you can see a good example of what I am trying to do hear:
Thanks in advance.
Francis De La Torre
Re: Pin Animation like NIN "Only" Video
on Mar 26, 2009 at 10:45:18 pm
Oh and BTW, this needs to be done on maya. =) hence posting in the Maya thread.
Alvaro Castaneda
on Mar 26, 2009 at 11:41:54 pm
HI
you could do this by getting the luma of your image and pump that in to the translation of the objects
you need to do this in the hypergraph with a few nodes.
varomix - pixelEater
http://www.intelianimate.com
Francis De La Torre
on Mar 26, 2009 at 11:56:03 pm
I have attempted this a couple times using displacement as well as with particles and instances. The flaw I am finding is that a video or image sequence cannot be used in either or those methods. I have done this kind of effect before in lightwave, and used that exact idea, however, I cannot piece the pipeline together in maya to make this thing fly. Any suggestions?
