My rotate tool has completely disappeared !!!!
COW Forums : Autodesk Maya
Susie Hampton
on Mar 26, 2009 at 10:44:02 am
Hi guys, im having a major problem thats really effecting me getting my uni project done.
Ive had maya for a while now never had a problem but today my roatae tool just completey disappeared. I reset the tool , made no difference. The others work fine move and scale but roatate is completely gone.
I was rigging when i found the problem so i decided to just try it on a new scene plain polygon cube, same thing, no roatate tool.
I really dont get it and it really holding me back , i have a lot to get done today.
Im on Maya 2008, windows 32bit, interl core 2 extreme oc at 3.5ghz, 4 gb ram, 2 x 1 gb hd radeon crossfires 3850's.
Thanks in advance for any help, you'll be a lifesaver:)
Alvaro Castaneda
Re: My rotate tool has completely disappeared !!!!
on Mar 26, 2009 at 3:14:29 pm
hi
try renaming the MAYA folder in your My Documents folder
if that works you are set, if you had like custom shortcuts and stuff you'll need to replace them, you can get some stuff from the old folder, the one you renamed
varomix - pixelEater
http://www.intelianimate.com
