Add specific CVs to Nurbs Planars
COW Forums : Autodesk Maya
Cristian Santana
on Mar 20, 2009 at 5:35:25 am
Hi Im new to Maya, and really need someone to tell me. It has been such a pain to add CVs to the center of Nurbs Planar to just pull a little a
trimmed circle to finish the model. I cannot even touch or add isoparms to the planar. Why is that? I just want to add a CV to the center of the
planar to pull it in the center. I used REBUILD SURFACE but I cant control entirely the CV positioning. Dont know if it can be done or cause I dont know how to do it. I will be very thankfull if someone helps me!!!!!!!!!!!Thank You!!!!!!!!! I just want total control of the CVs in a the NURBS or NURBS PLANAR!!! Can that be done?
Alvaro Castaneda
Re: Add specific CVs to Nurbs Planars
on Mar 20, 2009 at 3:16:10 pm
Right dlick on your surface an select Isoparm, then click on an existing Isoparm, those lines that cross the surface, click and drag to where you need your isoparm, you will need to make another one in the opposite direction to cross that and have a point where they cross
try it
varomix - pixelEater
http://www.intelianimate.com
