Animate object transparency (not fade in) more stylized, how to?
COW Forums : Autodesk Maya
michael zoppo
on Mar 16, 2009 at 3:56:21 am
Ok, so here is my question. I know i can of course just animate the fade in of an objects transparency tab. But what im trying to achieve is like a sweep almost, the object looks like it sweeps in. Imagine a vine that animates on by growing upwards and as it grows upwards it also becomes opaque. How would i go about doing this?
Alvaro Castaneda
Re: Animate object transparency (not fade in) more stylized, how to?
on Mar 16, 2009 at 4:32:10 pm
Hi
use a ramp to control the opacity of your shader and animate the colors of the ramp, that will help you
varomix - pixelEater
http://www.intelianimate.com
Gopalakrishna Palem
on Mar 1, 2010 at 3:44:53 am
Appreciate using Ramp textures.
But the transparency happens in the texture space, with the ramp occupying the whole texture of the object. I would like to retain the old texture for the parts that are still opaque. How to do it?
For example, I have this fish model with some texture (that has some complex UV mapped). Now, how do I apply my ramp transparency texture only to a portion of the object and let the remaining portion of the object use the old original texture?
Note that I would like to have the transparency creep in from bottom to top (or from left to right) instead of in UV space.
Help is appreciated.
Thank you,
Gopalakrishna
Creator of CFugue, the C++ MusicNote Programming Library
