Condensation on a bottle
COW Forums : Autodesk Maya
Adam McEwen
on Mar 12, 2009 at 1:53:05 pm
I am working on creating a bottle which needs to look cool and refreshing, i want to create condensation and water drops running down its side.
This is the look i am after:
http://forums.cgsociety.org/showthread.php?f=132&t=487154&highlight=water+d...
I have done something in the past where i sketched particles on to a surface but i cant for the life of me remember or find out how i did it. Any help much appreciated!
Adam
Alvaro Castaneda
Re: Condensation on a bottle
on Mar 12, 2009 at 4:00:57 pm
hi
If you have maya 2009, nparticles have a new sticky attribute that will make this so damn simple
varomix - pixelEater
http://www.intelianimate.com
Adam McEwen
on Mar 12, 2009 at 4:08:53 pm
Unfortunatly its 2008. It is possible to get quite a good look by using the pen tool to apply particles to the surface. I did it a while ago but i cant figure out how i did it. So frustrating!
Thanks anyway
Adam McEwen
on Mar 12, 2009 at 5:30:52 pm
Brilliant, iv solved it. I just needed to make the surface live by going in to Modify > Make live. Just a case of making the blobby particles look like condensation now!
Alvaro Castaneda
on Mar 12, 2009 at 8:23:05 pm
yeah, that works
you can also emit the particles from the can, or bottle, with out any velocity, only in frame one, as a surface emition then control them with fields, don't know if you need them to move
