transparent polygon faces
COW Forums : Autodesk Maya
joseph hider
on Mar 8, 2009 at 9:20:05 pm
i had a look around on the forum but didnt see anything on this topic. Could someone please give me some advice.
the system i am working on is a pc running windows xp.
currently using maya 2008. The problem i have is that some faces have gone transparent after i have extruded off some polygon edges. i will probably end up covering up these faces with a new plane but i was hoping there was an easier alternative.
i have tried to drop a new texture on the transparent faces but it jus disappeared after awhile. i have also tried to re-extrude the edges with the same result
any help would be appreciated
© 2018 All Rights Reserved
