Cloud/Fluid Rendering problem
COW Forums : Autodesk Maya
Andrew Minett
on Mar 6, 2009 at 3:49:46 pm
I'm trying to render out a sequence of frames using the cloudcurve fluid example. I can get a single frame to render normally at different points along the timeline but every time I try and do a batch render of a sequence of frames it results in blank frames being rendered out.
Any idea what's going on here?
I can provide the project file (maya 2008) if you'd like to take a look at my settings.
Cheers,
Andy
