Transfer UVs from one object to another
COW Forums : Autodesk Maya
John Peterson
on Mar 4, 2009 at 9:17:22 pm
I’m transferring UVs from one tire to the other 3. All works fine until I smooth or otherwise alter the original. I can’t delete history because the tires have deformers on them. I’ve tried deleting non-deformer history but that doesn’t affect it.
How do I kill the transfer attributes connection after I transfer so that the UVs are local to each object and not dependent upon the original?
Alvaro Castaneda
Re: Transfer UVs from one object to another
on Mar 4, 2009 at 10:01:06 pm
I found a solution to this, is kinda complicated
You first need to duplicate your target object let's say TIRE_2
transfer UVs to that, delete history on that object
then replace that geometry
that would work
varomix - pixelEater
http://www.intelianimate.com
John Peterson
on Mar 4, 2009 at 10:16:06 pm
Thanks for the quick response. Will this work if the car and tires are already rigged?
Alvaro Castaneda
on Mar 4, 2009 at 10:21:28 pm
yeah
I used this to replace full skinned/rigged/animated characters :P
John Peterson
on Mar 4, 2009 at 10:35:52 pm
I'll give it a shot. Thank you very much.
John Peterson
on Mar 4, 2009 at 10:38:53 pm
Just to be clear: Duplicate geometry. Transfer UVs to duplicate. Delete history on duplicate. Replace original target tire with duplicate.
Do I have that right?
Alvaro Castaneda
on Mar 4, 2009 at 11:29:08 pm
exactly !!
