volume rendering
COW Forums : Autodesk Maya
selwyn dsouza
volume rendering
on Feb 19, 2009 at 1:31:27 am
need to render a cross section of an object in maya but since objects are hollow only edges show up.Is there a way to render volume.i dont want to use particles and booleans dont seem to work
Alvaro Castaneda
Re: volume rendering
on Feb 19, 2009 at 9:54:14 pm
hi
create a cap for the object, using the fill hole command from the mesh menu
if you have more than one Boundary, select one edge of the hole before using fill hole
varomix - pixelEater
http://www.intelianimate.com
selwyn dsouza
on Feb 22, 2009 at 11:13:39 pm
actually need sometihin like this in the end result http://video.aol.com/video-detail/maya-cut-away-boolean-shader-network/2427...
