[help] circular fillet
COW Forums : Autodesk Maya
fadly habibi
on Feb 10, 2009 at 1:58:39 am
hello
this my first post , im currently using maya 8,5..
i already following below tutorial:
Understanding Nurbs primitives car wheel by Nelson Cruz
but i have a problems..if im try to circular fillet 2 nurb object..both object doesnt changed at all
see ; http://i41.tinypic.com/b892co.jpg
i already for chnge tangent n positional object but nothin happen..
thx for help
Wesley Adams
Re: [help] circular fillet
on Aug 14, 2009 at 12:13:29 am
I was having some problems as well at this point but I found out that if you over lap the two nurb surfaces, you should get the fillet surface you need. If it appears reversed (in the front of revolved nurb) select the Reverse primary surface normal option box. Still tinkering with this one but I hope it helps.
-Wes
Wesley Adams
on Aug 14, 2009 at 12:52:34 am
By the way, if you have any other problems further down the tutorial, I found this thread helpful:
http://forums.creativecow.net/archivethread/61/675434#675434
Wesley A. Adams
CCAD Student 2010
Animation Major
3D Animator
