Rendering problems
COW Forums : Autodesk Maya
Sofie Edvrardsson
Rendering problems
on Jan 29, 2009 at 3:36:06 pm
Hey!
I have a trouble with my rendered images form Maya.
The floor has some strange black stripes.
Is there someone that knows what the problem is?
Like every 5:th frame is bad.
I've tried to change the texture of the floor but it dosnet matter.
I have rendered in mental ray, production
Here is an image. Sorry that its a bit bright.
http://www.informatik.umu.se/~dmph0707/vy2.17.png
Alvaro Castaneda
Re: Rendering problems
on Jan 29, 2009 at 5:24:17 pm
try
turn off cast shadows for the floor
select the object > under render stats uncheck casts shadows
varomix - pixelEater
http://www.intelianimate.com
Sofie Edvrardsson
on Jan 29, 2009 at 6:13:02 pm
Hey, thanks for the fast answer.
I dont think that I found what you wanted me to uncheck.
I'm just a beginner so far. :)
Where is the render stats?
But I turned off the lights influence on the floor using
Light-linking, but that didnt make a difference.
I also unchecked Raytracing and that didn't work either.
Thanks / Sofie
Alvaro Castaneda
on Jan 29, 2009 at 7:10:44 pm
SELECT THE OBJECT OPEN THE ATTRIBUTE EDITOR BY PRESSING CTRL + A
IN THE SHAPE TAB, THE ONE THAT IS NAMED your_objectnameShape
SEARCH FOR RENDER STATS THERE AND OPEN IT
Sofie Edvrardsson
on Jan 30, 2009 at 2:23:36 pm
Thanks!!! :)
