mental Ray IBR
COW Forums : Autodesk Maya
Adam Roestenburg
mental Ray IBR
on Jan 25, 2009 at 6:23:59 am
I am trying to use an HDR image as a background plate for a render.
I have created a mental ray environment IBL. The background is visible in the view port
and when I do a single frame render.
I have put the mental ray ibl node into its own layer along with the default light set
However when I attempt to batch render this layer the HDR image is not visible.
any ideas?
Alvaro Castaneda
Re: mental Ray IBR
on Jan 27, 2009 at 5:50:21 pm
Do you need the HDR to LIGHT your scene, or just use it as a background?
if you need it for both you could add a big sphere or a plane, depending of how much camera move you have, and texture that with that image, I suggest you do this on a separate layer, that way you have more control of composition, if not just trow a render like that.
varomix - pixelEater
© 2018 All Rights Reserved
