Lightwave obj to Maya
COW Forums : Autodesk Maya
Scott Kaser
on Jan 22, 2009 at 2:47:21 pm
Having a little trouble getting an obj file from Lightwave to Maya. I've exported the file from Modeler using Export OBJ. When I import the file into Maya, nothing loads or I get an error message. I'm going through the import options and telling it File Type: OBJ. I can get obj files to load into Maya, just not the ones coming from Lightwave. This should work. What am I missing?
(I'm running a Quad-Core Macintosh)
Alvaro Castaneda
Re: Lightwave obj to Maya
on Jan 22, 2009 at 4:34:38 pm
HI
that's odd
try FBX or any other format
also you can open the OBJ in a text editor and check if there's any difference with other OBJ files
varomix - pixelEater
http://www.intelianimate.com
Scott Kaser
on Jan 22, 2009 at 6:46:13 pm
Not sure how to get an FBX file out of Lightwave. (v8.3)
Juan Hernandez
on Jun 19, 2009 at 7:26:19 pm
Here you go, I made a quick tutorial for you...for free. I had a similar problem knowing I migrated OBJ's with UV's before. Well here is a small basic run down covering small entities needed prior to your Maya integration from Lightwave.
http://www.cyphermesh.com/16.html
Incase you cant see on the website...go to...
http://vimeo.com/5234712?pg=embed&sec=
Still cant view it... try downloading current Flash media player at Adobe.
I hope this helps!
-3Dementia @ http://www.CypherMesh.com
