Rotation Problem
COW Forums : Autodesk Maya
Casey Faris
Rotation Problem
on Dec 29, 2008 at 7:23:18 pm
Hi, So sometimes I will try to rotate a mesh and it stretches severely. This is usually after I parent it to something. I think it may be a hierarchy problem. Can anyone tell me why this happens and how to make it stop? Thanks!
-CF
Lars Bunch
Re: Rotation Problem
on Dec 30, 2008 at 2:10:19 pm
I don't know if this is really an answer to your issue, but deleting the mesh's history and freezing transformations seems to help in this situation.
Hope this helps,
Lars
Casey Faris
on Dec 30, 2008 at 4:05:33 pm
No, that doesn't work. any other ideas?
Casey Faris
on Dec 30, 2008 at 8:19:50 pm
I sort of fixed it. I had to do with the transforms of the parent circle. the scale wasn't uniform (1,1,1), I also reset all transformations, which, from what I understand, does away with a -1 scale etc. Thanks.
