Curving fonts in Maya 2008
COW Forums : Autodesk Maya
Paul Burke
on Dec 21, 2008 at 8:42:28 pm
I trying to get a imported font from AI which is beveled in Maya to curve or arch.
Can anyone give me a hand with this?
Thanks and Merry Christmas.
Blurke
Andrew VanWickler
Re: Curving fonts in Maya 2008
on Dec 22, 2008 at 4:16:44 pm
Select the text and separate it so that each letter is a separate polygon and can be moved individually.
or
try creating a curve. Then select the text followed by the curve. Then making a wrap deformer. Now you can edit the cv's on the curve to deform the text as you please.
Andrew VanWickler
vanwyklr@3dvw.com
http://www.3dvw.com
Andrew VanWickler
on Dec 22, 2008 at 6:17:38 pm
Another way of doing this would be to take your text and attach it to a motion path of an arch. Then create a flow path (add more divisions for more of a bend. Then play the timeline. Stop it at whatever point you like the arch then delete the history.
Andrew VanWickler
vanwyklr@3dvw.com
http://www.3dvw.com
