Desperate Need of Help!!
COW Forums : Autodesk Maya
Salima Nesbitt
on Dec 7, 2008 at 5:03:04 pm
I'm trying to render something out in Maya, using Mental Ray. I went to work on the scene at another location, and proceeded to render out a test render. When I rendered it out the files were there, but there's no data on the file. I use a Mac so normally you can see the files' icon on the file, but this is just blank and white. So I went home and the same thing is happening. I tried a new file and it's still the same even not using Mental Ray. Before this it worked perfectly at home. Is there something I'm doing wrong.
Please Help.
Steve Sayer
Re: Desperate Need of Help!!
on Dec 8, 2008 at 5:33:34 am
Double-check the file type set in the Render Settings window. It may be set to a type that isn't associated with any application on your computer(s). Choose a format you know you can open and render again.
-Steve
Salima Nesbitt
on Dec 10, 2008 at 9:46:08 pm
You were right thanks for your input.
