Fade between shaders/colors during animation
COW Forums : Autodesk Maya
paul kramer
on Nov 30, 2008 at 7:33:40 am
Hello,
I’m needing to simulate a change of time from day to night in a surface shader. At the moment I have the surface shader connected to a blue and white ramp to simulate day; now I need to somehow change this shader’s color further down the animation time line to black in order to simulate night. What would be the best method to achieve this effect?
Thanks in advance,
Paul K
Chad Briggs
Re: Fade between shaders/colors during animation
on Dec 1, 2008 at 6:23:32 am
If you want to do as little work outside of maya as possible, just animate the ramp color/positoins to get the effect of the surface shader changing day to night. Another method would be to render out two passes, one with the day look, one with the night look, and fade between them. Depending on how anal you want to be, you'll have to take in to consideration the shadow movement as the sun moves across the sky as well as the moonlight shadows.
-chad
