raytrace setup ?
COW Forums : Autodesk Maya
alek panfilov
raytrace setup ?
on Nov 19, 2008 at 11:13:51 am
hi all,
mayby someone could help me with my problem, generally i can’t make a setup for raytrace relations of my objects in scene ( sorry if i’m not precise in my words ).
in scene i’ve got reflective floor, main object and a surface which is illuminating reflections on main object .
the issue is that i want the reflection on the floor to reflect main object and its surface reflections but without that surface.
i know that with normal lights it would be easy, light linking and that’s it. but when i got a surfase which is illumination i just can go over it.
i’ve attached preview img and project is at :
http://www.dzeday.pl/test01.mb
if somebody could help me , i’ll be very gratefull :)
best,
alek panfilov
Alvaro Castaneda
Re: raytrace setup ?
on Dec 3, 2008 at 3:52:51 pm
hi
Add a useBackground shader to your floor object.
nice logo :D
varomix - pixelEater
http://www.intelianimate.com
Alvaro Castaneda
on Dec 3, 2008 at 4:33:26 pm
Sorry
I understood your problem when I saw your file, I don't think there's a way to do it in MR, you could try and change that ring for a real area light and choose the cylinder option for the area light, that, can give you almost the same look
l8r
