extrude circular face out of cylinder?
COW Forums : Autodesk Maya
Lefteris Sifidis
on Nov 5, 2008 at 6:48:11 pm
Can someone please tell me how I could extrude a circular inner part of the upper face of a cylinder? (with the same center as the face)
Lefteris Sifidis
Re: extrude circular face out of cylinder?
on Nov 5, 2008 at 7:29:40 pm
To be exact, the question is how can I extrude a face out of the already extruded face? (like a telescope). The first time is easy, I increase the caps # and select the inner circular face, but the extruded cylinder that is created does not have any caps attributes to it..
Steve Sayer
on Nov 6, 2008 at 5:45:21 am
I assume you're talking about a poly cylinder, here.
The 'extrude' command should do what you're looking for, without needing to increase the number of divisions on the caps. Just extrude the faces, then scale the newly extruded faces down, then extrude them again--that will provide the 'stair-step' or 'telescope' pattern you're looking for.
Alternately, you could set the cylinder to have a high number of divisions on the cap, then select all but the largest ring and extrude... deselect the next largest ring and extrude again... and repeat for as many stages as you want.
-Steve
