Noob question, how on earth are regular folk expected to ...........
COW Forums : Autodesk Maya
Dwight Spitz
on Oct 18, 2008 at 5:59:35 pm
How and what method do people use to export their animations, and i'm not talking playblast, as a person only familiar with NLE like FC and Premiere, totally new to Maya, how do we get that stuff out?
k, thanks,
Nick vand
Re: Noob question, how on earth are regular folk expected to ...........
on Oct 23, 2008 at 7:45:18 pm
erm Image sequence then post process and bump out whatever you like through your editor?
...or export an avi directly from Maya itself?
jim cascarina
on Oct 24, 2008 at 3:49:13 pm
I'm going to assume you literally can not find where you need to go.
in which case first hit the icon that looks like a clapper board on the very top menu or go to window/render settings. this is called render globals. set up things like frames size and format i.e. quicktime or image sequence etc in here.
then hover mouse over one of your view ports and hit space bar to bring up the big marking menu somewhere on there you will find "render" in there you will find batch render hit that press ok, and...........in a few days you will have your first render.
hope this helps?
Nick vand
on Oct 24, 2008 at 6:23:45 pm
...that was a much better explanation than mine :)
