Maya Parent Object to Vertex?
COW Forums : Autodesk Maya
Mark Walczak
on Sep 30, 2008 at 9:43:36 pm
Hey everyone,
I am working on animating a tree. I have the trunk and a branch, both seperate objects. I am doing a simple scale on the tree trunk in order to make it grow on the y-axis. I also have a tree branch with some animation. I am trying to in some way "parent" the tree branch to a specific vertex on the tree trunk in order to make the branch follow a particular point on the trunk as it scales. Any thoughts?
I tried using "Transfer Attributes" to no avail, but it was the closest thing yet. I have also tried creating clusters, however, as I found out, the cluster will remain in one place if I am scaling the trunk.
Any and all advice is greatly appreciated, and thank you in advance!!
What makes you explode?
http://www.explosivegraffix.com
Chad Briggs
Re: Maya Parent Object to Vertex?
on Oct 1, 2008 at 2:11:29 am
your best bet is going to be to download a plugin called "rivit" (or something like that) from highend 3d. It automates the process of constraining objects to the surface of a polygon/nurbs object.
-chad
Mark Walczak
on Oct 1, 2008 at 4:48:35 am
Thanks Chad! I'll give it a look tomorrow!
Jack Leto
on Oct 1, 2008 at 2:28:38 am
this all depends on your setup..
attach the branch to your trunk (there must be a reason why you havent attached it though),
or create a set driven key (where the scale drives the transform)
MOTIONOLOGIST
