problems extruding edges on sub poly mesh
COW Forums : Autodesk Maya
jonathan king
on Sep 1, 2008 at 4:50:54 pm
My problem consist of not being able to extrude the edges/faces of a polygon cube that has been converted to a sub poly mesh was extruding fine before i had this problem. When ever i try to extrude edge i get this message. // Error: polyToSubdiv1 (Poly To Subdiv Node): One or more edges is nonmanifold.i have the same problem when extruding faces. All i get is a wire frame of what i want to extrude i deleted my history. i did the mesh clean up. Even installed the new service pack. Still nothing. If any body can help i would really appreciated
