Hypershade connections
COW Forums : Autodesk Maya
German Garces
on Aug 26, 2008 at 4:27:56 am
Hi everyone
How do I keep the hypershade nodes connected after I close maya?
for instance I want to keep the visual representation of my work without recreating it, Maya seems to forget the connections in the lower right window in the hypershade.
Any help would be appreciated
keith mcgregor
Re: Hypershade connections
on Sep 15, 2008 at 6:19:37 pm
"How do I keep the hypershade nodes connected after I close maya?" If you close maya, the hypershade will close too, and it doesn't forget. If you want to see your connections, mmb-drag the material into the work area of the hypershade, right click and choose -graph network- and presto! it all shows up!
Reality? What did you make it?
German Garces
on Oct 9, 2008 at 4:19:05 am
your tip helped me a lot.
I was able to finish all my bottles, thought with some artifacts
See the following screenshots:
http://www.withoutcolor.com/cow/artifact001.png
Thanks again
