Extruding issue
COW Forums : Autodesk Maya
Glenn Moore
Extruding issue
on Aug 21, 2008 at 5:00:11 am
Man, it's been a while since I posted. I have a scene I'm working on that has a street/alley. I start with a polygon plane (40 x 30) with 10 x 10 subdivisions. I insert edges to create a curb on either side of the street. My goal is to lower the street portion by selecting the faces of the street leaving the curb and sidewalk elevated slightly.
Problem: I select the faces and extrude. The street section drops but leaves walls where the lines separating the 10 x 10 subdivisions were. Kinda like a bunch of square swimming pools. I've seen this done and it works. Can anyone tell what I'm doing wrong from that description?
I'm using Maya 8
Thnks in advance
Glenn Moore
Re: Extruding issue - Got it!
on Aug 22, 2008 at 3:21:43 am
I forgot to 'Keep Faces Together'. What a noob.
If you're gonna do it, try to do it well...if you can't do that then try to cover up your mistakes really well.
