creating transparent ground
COW Forums : Autodesk Maya
jason leue
on Aug 20, 2008 at 10:17:02 pm
I have a ground plane the trees and rocks are penetrating.
I want to composite in a floor later, but I need the floor to cut off the trees and rocks where the floor would be so when I add a new floor the trees and rocks sit nicely on the new composited ground with composited shadows.
I could do this by keying out the ground in fcp but I think there's an easier way.
which shader should I use for this?
which settings would I need to change?
thanks a lot!!
Jason
Alvaro Castaneda
Re: creating transparent ground
on Aug 24, 2008 at 12:48:08 am
hi
use the use background shader, does exactly what you need
varomix - pixelEater
http://www.intelianimate.com
