Animation on a path and exploding objects
COW Forums : Autodesk Maya
Ray Jender
on Aug 8, 2008 at 3:19:54 pm
I am experimenting with Maya. What I am trying to do is create an animation of two separate objects that basically fly around a little,
then crash together and explode. I have discovered the "animation on a path feature". Very cool. Now I need to learn how to do the exploding.
Actually, I would like the explosion to look like breaking glass.
Any tutorials on something like this?
Ray
Ray Jender
Re: Animation on a path and exploding objects
on Aug 11, 2008 at 1:04:21 am
So I'm playing with animation on a path. I can get the object to follow the path but the object is facing the wrong way. I want the front of the object to always be aligned with the path.
How?
Ray
Alvaro Castaneda
on Aug 16, 2008 at 5:50:45 am
select the object hit ctrl+a in the attribute editor find the motionpath tab, change the front axis and Up axis to fit your needs
varomix - pixelEater
http://www.intelianimate.com
