Looping an ocean
COW Forums : Autodesk Maya
Jonathan Bliss
Looping an ocean
on Aug 5, 2008 at 2:33:08 am
Hi guys,
I am working on a project in maya of a pirate ship moving through an ocean. The ship is going to be interactive so when you turn a wheel the ship will turn as well, and then back again.
I need to know how i would be able to loop the ocean fluid fx animation, so the waves meet up on the first and last frames.
does anyone know how to do this?
thanks in advance
Alvaro Castaneda
Re: Looping an ocean
on Aug 16, 2008 at 6:15:17 am
you can try making a transition in after effects, fading in an area that is almost the same, or you could reverse the animation, lets say if you have 0 to 300 frames you let that run and copy that at the end, run it again in reverse 300 - 0, might work.
varomix - pixelEater
© 2018 All Rights Reserved
