problem with interactive placement
COW Forums : Autodesk Maya
Ryan Kenelly
on Aug 5, 2008 at 12:33:37 am
When I try to move a texture on a nurbs surface using interactive placement tool it doesn't show me the handles plus it doesn't move interactively as it should. If anyone know anything about this please reply, thanks!
German Garces
Re: problem with interactive placement
on Aug 26, 2008 at 4:22:47 am
I had the same problem until this weekend that I realized I was using the wrong tool, the interactive placement tool is a pain when placing files in cylindric shapes.
Instead I am using the "projection" option which is way more flexible than the "normal" 2d texture node.
Not sure if this will help you any, but changing this little radio button to projection made my maya-beginner life a lot easier.
