Help with displacement maps
COW Forums : Autodesk Maya
Fintan wilson
on Jul 31, 2008 at 4:43:31 pm
This may seem trivial but i can't figure it out.
the image displaced on the surface is only a part of the original displacement image.
for example. I'm busy modeling a coin, i want to use displacment maps to extrude the head image on the one side of the coin. However when i do this only a part of the head is extruded, for example the eye.it's as if the displacement image is way to big for the coin. Is there a way to resize the displacement image?
It was working fine earlier today, but it think i might have changed a setting or something. Can Anyone plaese offer me a solution?
Alvaro Castaneda
Re: Help with displacement maps
on Jul 31, 2008 at 7:00:35 pm
Hi
Check your Uvs you might have something bad there
varomix - pixelEater
http://www.intelianimate.com
Fintan wilson
on Jul 31, 2008 at 7:32:08 pm
Hi there.
checked all my UV's, even opened up previous files that worked and got the same problem.
I can't understand it
Fintan wilson
on Aug 1, 2008 at 12:39:38 pm
OK, it has to do with my uv sets.
When i place the image, it adds it to the default uv set. I have created a different uv set, but it still uses the default set, even if i only select the surface i want th image on.
how do i change which uv set to use
